น้าอ้อนไปไหนมาทำตู้นี้เลย
Technical Data:
Rated power 200 W
Maximum power 350 W
Nominal impedance Z 4 Ohm
Frequency response 40-18000 Hz
Mean sound pressure level 99 dB (2,83 V/1 m)Cut-off frequency 1600 Hz / 9500 Hz
Principle of Housing geschlossen / closed
Net volume 200 l (38 l + 2 x 39 l + 2 x 42 l)
Outer dimension height 1557 mm
Outer dimension width 315 mm
Outer dimension depth max. 634 mm
http://www.rumoh.eu/nl/fullrange-kits/3990-pentaton-bb-per-paar.html
