ผู้เขียน หัวข้อ: DHT Filament Regulator  (อ่าน 9007 ครั้ง)
ออฟไลน์ darkman
  • กระทู้: 225
  • ถูกใจกด Like+ 69
« เมื่อ: 10 กุมภาพันธ์ 2014, 04:12:52 PM »
ใครพอมีข้อมูล หรือสนใจเจ้าตัวนี้อยู่บ้างครับ
Rod Coleman DHT Filament Regulator
เค้าสาธยายสรรพคุณ ประมาณว่า LM317 ที่เราใช้ทำ DC จุดใส้หลอด DHT กันอยู่ noise มันเยอะ ไม่เหมาะกับงาน audio
วงจรจุดใส้หลอดที่เค้าออกแบบจะให้ข้อดีดังนี้
“There are [at least] 4 reasons to use athe CCS/gyrator architecture:
1.   Establish a high dynamic impedance between the Filament terminals. I don’t know if there’s some kind of micro-phasing effect, or something else, but it is certainly important. If you connect this circuit to a DHT and enjoy the wonderful sound for a while, then try putting a 1uF across the filament – the sound is degraded below AC standard.
2.   Minimise hum without interfering with the anode current. The gyrator is an open-loop regulator, while the CCS has feedback network which is not in contact with the filament. There’s a big difference. I tried circuits with opamps and other feedback methods, even rolled off as a 2Hz servo, but if the feedback network is in contact with the filament, you lose out on the sound. One can only assume that the anode current is being sensed by the feedback, partly, and causing interaction with the CCS pass transistor.
3.   Because the filament is the cathode, and the cathode is part of the DHT’s input [the grid-cathode voltage drives the DHT], imagine having the input circuit snaking around on long wires, picking up fields, and capacitively-coupling the input circuit to ground through horrible dielectrics (like PVC wiring). But that’s just what happens with AC-heat, and dc-rectified heating. That is why ac-heat sounds different with different transformers – although it always sounds bad compared to CCS heat.
4.   The CCS/Gyrator transistors buffer the filament from the filament trafo & rectifiers, and gives more consistent, and hugely better sound.
5.   Current limited control prevents big turn-ON current. My 300Bs measure 0.7-ohm cold, so they would see ~8-Ampere peaks at startup. That maybe why mine have already lasted nearly 12 years constant use, whereas filament breakage seems to be the biggest failure mode for 300Bs”.
รายละเอียดครับ http://lyrima.co.uk/dhtreg/dhtRegIntro.html
ผมเองไม่มีความรู้ด้านการออกแบบวงจร solid พวกนี้เลยครับ  ก็ผมเลยเอาแนวคิดใหม่มาลองเสนอท่านที่มีความสามารถด้านนี้ดู  เผื่อท่านใดจะสามารถนำแนวคิดแบบนี้มาทำ PCB ให้ใช้งานกันภายในหมู่บ้านเราบ้าง น่าจะเป็นประโยชน์ในวงการได้บ้างครับ  อีกอย่างนึงวงจรนี้นอกจากจะใช้จุดใส้หลอด DHT แล้ว เค้ายังเอามาใช้ในเทคนิค filament-bias ได้อีก
แบบนี้น่ะครับ
รายละเอียดครับ http://vinylsavor.blogspot.com/2012/03/filament-bias-part-1-concept.html] [url]http://vinylsavor.blogspot.com/2012/03/filament-bias-part-1-concept.html[/url]
ถ้าใครออกแบบได้ผมยินดีเป็นหนูให้นะครับ อยากเอามาใช้กับวงจรแนวๆ นี้น่ะครับ
ออฟไลน์ darkman
  • กระทู้: 225
  • ถูกใจกด Like+ 69
Re: DHT Filament Regulator
« ตอบกลับ #1 เมื่อ: 10 กุมภาพันธ์ 2014, 04:17:00 PM »
มีอีกคนนึงแกออกแบบไว้  แล้วเปิดเผยวงจรด้วย เค้าบอกว่าหลักการเดียวกัน ผมก็ไม่รู้ว่าจะใช้ได้หรือเปล่า
แบบนี้ครับ
