ผู้เขียน หัวข้อ: single triode loctal 9 pin- B9G  (อ่าน 6061 ครั้ง)
« เมื่อ: 05 พฤษภาคม 2019, 09:29:44 PM »
EC52 mullard single triode hi mu
http://www.r-type.org/pdfs/ec52.pdf
Re: single triode loctal 9 pin- B9G
« ตอบกลับ #1 เมื่อ: 05 พฤษภาคม 2019, 09:43:35 PM »
EC52 Mullard single triode Hi Mu
The EC52 is a small transmitting valve from the early days of all glass construction. It was designed for VHF operation, and probably mobile equipment. It was originally given the Type designation of .
The picture shows the flattened oxide coated cathode and the gold grid wire can also be seen. The anode is carbonized. The whole electrode assembly takes up less than half of the envelope, and a second valve could be physically fitted into the envelope.
The wide glass tube envelope is 30 mm in diameter and, excluding the B9G base pins, is 55 mm tall.
>>> http://www.tubecollector.org/cv1137.htm
