ผู้เขียน หัวข้อ: Fake Cardas SRCA Plugs with Cardas Logo!?!  (อ่าน 10151 ครั้ง)
« เมื่อ: 14 มกราคม 2012, 06:30:07 PM »
เจอมาจากเว็ปตา jimmyauw ขอไม่แปลนะครับเกรงว่าตะตีความเข้าใจไปคนละแบบ  [c--c] จะยิ่งสับสนกันไปอีก จึงขอยกมาเป็นช่วงๆ แต่จะลง link ต้นฉบับใว้ให้ด้านล่างครับ  [smi_ley]
Should I say I?m lucky or not? That I have both type of SRCA on hand? >.<
From the physical side, in general, they are similar. But there are some visible clue like shown below. The tip of the plug on the fake one is well rounded, while the original one is slightly sharper. Off course, no logo on the original one as mentioned by the email above. Last, the reflection of the copper barrel also quite different. A little bit difficult to be seen with bare eyes, but quite clear on the photo.
Zoomed version of the copper barrel. Can you see the different? The original one got better texture and build quality, also leads into better reflection on the photo.
The Teflon shield to separate the ground and the signal also got some gap on the original one. Meanwhile the fake one got a flat style.
The signal side also smaller and shorter. The build quality also not as good as the original one.
Inside shoot of the Teflon separator between the signal and ground connector. The fake one got a flat model, meanwhile the original one got an extra gap there.
The ground connector also got slightly different model.
Another ?best? thing is the Cardas logo ? even it?s fake ? it?s really well made. Below is two copper barrel of the fake SRCA. I use Brasso Metal Polish to polish the barrel. Normally, this kind of fake stuff will use cheap stamping. If that?s so ? surely the logo shall be removed easily with Brasso ? as this is quite strong cleaner. But as you can see, the left barrel has been polished (and got brighter and shiny color), but the Cardas logo remains intact! I tried to wipe them seriously, but got no result to erase it. Despite it?s fake status, I think this is really a ?serious and well made? item. I put two thumbs up for the build quality of this fake Cardas SRCA (but off course, I don?t agree with counterfeit item). So, fake is a fake? and spending money to buy fake item was not a good experience in my life
เอาหละครับ คงจะพอเป็นแนวทางกันได้บ้าง เวลาไปเดินๆเกิดเจอแล้วเห็นราคาไม่แรงนักก่อนซื้อ หยิบมาดูซักนิด จะได้ไม่เจอของปลอมราคาใกล้เคียงของแท้กันครับ หรือหากสนใจลองติดต่อ ตา CreAte HoUse ดูครับ  [smi_ley] (ค่าโฆษณาด้วยนะเพ่)
ที่มาครับ Fake Cardas SRCA Plugs with Cardas Logo
อันนี้นอกเรื่องแต่หนูอยากได้แบบนี้วันเด็กบ้าง ง่าาา  [c--c]
ออฟไลน์ prapan2012
  • กระทู้: 120
Re: Fake Cardas SRCA Plugs with Cardas Logo!?!
« ตอบกลับ #1 เมื่อ: 14 มกราคม 2012, 07:50:16 PM »
5555 ใช้ของปลอมตั้งนาน มิน่าทำไมหัวดำเร็วจัง [laugh-raccoon]
ที่อยู่คับ และ บัญชีโอนเงิน
« ตอบกลับ #2 เมื่อ: 15 มกราคม 2012, 12:41:23 AM »
ชอบ ๆ หามาหลาย ๆ ยี่ห้อ จะได้ไม่โดน [phok]
« ตอบกลับ #3 เมื่อ: 15 มกราคม 2012, 12:45:29 AM »
 [smi_ley] นานๆเอามาลงทีละกันครับ กระทู้ได้รับความสนใจเยอะไปหน่อย  [entreat-raccoon]
« ตอบกลับ #4 เมื่อ: 15 มกราคม 2012, 02:57:37 AM »
ยังไม่เคยซื้อหัวยี้ห้อนี้ใช้เลย ถ้ามีโอกาสจะได้ไม่พลาด แต๊งกริ้ว [yes-raccoon]
« ตอบกลับ #5 เมื่อ: 15 มกราคม 2012, 07:34:29 AM »
 [clap hand2]
ออฟไลน์ MonAudio
  • ดีที่สุด...ในจุดที่ยืน
« ตอบกลับ #6 เมื่อ: 15 มกราคม 2012, 11:22:38 AM »
ยังไม่มีตังค์ซื้อ  แต่ก็จะได้รู้ไว้...ป้องกันโดนหลอกครับ
ขอบคุณครับ  [clap hand2]  [clap hand2]
