ผู้เขียน หัวข้อ: CD player  (อ่าน 35256 ครั้ง)
CD player
« เมื่อ: 16 มกราคม 2012, 03:22:20 PM »
C515BEE CD Player Features   7900 บาท
[/size][/size]
    Plays CD, CD-R/W
    Decodes MP3 and WMA files copied to CD-R for up to 10 hours of continuous play
    24/192 Sigma/Delta D/A converters are chosen for low noise and excellent linearity
    Audio specific OP Amps assure accurate musical sound
    Carefully chosen capacitors and other passive components with close tolerances for critical circuits
    Full function remote control
    Repeat function for 1 song, 1 disc, or A-B repeat
    Program play with direct access from the remote control
    Forward and reverse skip and search function
    Informative VFD display gives complete information about tracks and time
    Display dimmer
    COAX and Optical digital outputs
    Compact size matches the NAD C315BEE Amplifier
NAD C515BEE CD Player specifications:
CD Player
Disc capacity    1
Frequency response    5Hz - 20kHz    + 0.5dB (ref. 0dB 20Hz-20kHz)
De-emphasis error    -4.53 + 0.5dB -5kHz -9.04 + 0.5dB - 16kHz
THD (at 0dB, 1kHz)    <0.003%
Dynamic range    95dB
Linearity    + 0.01dB (0 to -60dB)
S/N ratio, A-weighted    110dB
Channel separation    @1kHz    95dB
@10kHz    95dB
Output level at 0dB    2.2V
Physical Specification
Dimensions (W×H×D)    Imperial    17 1/8 x 2 3/8 x 9 1/2”
Metric    435 x 60 x 241mm
Net Weight    Imperial    7.75 lbs
Metric    3.52kg
Shipping Weight    Imperial    10.34 lbs
Metric    (4.7kg)
* NAD reserves the right to change specifications or design at any time without notice. All specifications are those in effect at time of printing.
MARANTZ : CD-5003  9900บาท
The CD5003 CD player is the entry-level player in Marantz?s acclaimed range of CD players. However, it has already made a fantastic name for itself. The CD5003 employs high-quality audio components such as the well-known CS4392 digital-to-analogue converter, Marantz?s own HDAM SA2, and a dependable CD transport mechanism, deliver high musicality. The rigid chassis and solid metal front panel provide a rock-solid base. The CD5003 is feature-packed too: an Audio EX(clusive) mode even further excels sound quality with the Switch Off function for pitch control, digital output and the display itself. It also plays CD-R and CD-RW, MP3 and WMA discs and displays CD-Text information such as artist name and track titles. The Auto Music Scan (AMS) quickly finds the music on the disc and the Quick Replay enables to repeat favourite passages. The pitch control allows adjustment of the playback speed and a choice of coaxial or optical digital outputs combined with the high-grade gold-plated analogue out guarantees the best connectivity. A well-defined headphone output and supplied remote control completes the picture of this excellent player.
    Compatible with CD, CD-R/RW, MP3 and WMA
    New solid reference-standard chassis
    CD Text on front panel display (when available)
    High-quality audio output stage with HDMA SA2 in current feedback architecture
    High-quality audio components
    High-quality multi-bit D/A conversion via CS4392 DAC
    Pitch control off, digital out off and display off function to minimized high frequency noise interference
    Headphone output
    Digital coaxial and optical outputs
    Auto Music Scan
    Pitch control (+/- 12 steps)
    Detachable power cord
    Dedicated remote and Marantz D-Bus
Onkyo DX 7355 (BLACK)  7900 บาท
Sublime Sound Quality and Ultimate Fidelity for CD/MP3 Sources
As compelling as the new high-resolution audio CD formats are, the sheer mass of music titles available ensures that CD playback will be with us well into the foreseeable future.And with the emergence of digital music formats such as MP3, we can also see computerbased files finding a place with quality audio systems.The DX-7355 CD player brings this added dimension to your music entertainment. Look to the fundamental design concepts of separate, audiophile-quality playback components?a precise digital-to-analog conversion section (with a high-quality DAC); a large, well regulated power supply; competent analog circuits; and a vibration-resistant design.You?ll find them expertly bundled into the DX-7355 CD player that draws on Onkyo?s technical design skill and musical sensitivity.
Features
? Plays Audio CDs, MP3-Encoded CDs, CD-R/CD-RWs*
? VLSC (Vector Linear Shaping Circuitry) to Reduce Digital Noise
? High-Quality Wolfson? (WM8716) 192 kHz/24-Bit DAC
? Large Power Transformer for Consistent Power
? Audiophile-Grade Capacitors
? 2 Digital Outputs (Optical/Coaxial) to Connect with an External Digital Processor or Amplifier
? Headphone Jack with Volume Control
? Quick Navigation for MP3 CD Playback
? 4 Play Modes (Group [MP3 CD only]/Memory/Random/Normal)
? 25-Step Memory Playback
? 5 Repeat Modes (1 Group/Memory/Random/Entire Disc/1 Track)
? 3-Mode Dimmer (Normal/Dim/Dimmer) Function
? High-Rigidity,Anti-Resonant Chassis to Reduce Vibrations
? Brushed Hairline Aluminum Front Panel
? RI (Remote Interactive) Remote Control Capability
* Discs that have not been properly finalized may only be partially playable or not playable at all.
Features
MP3
MP3s are digital audio files that have been compressed, yet which still maintain the sound quality of the original. Before there were MP3s, digital audio files took hours to download. But on a 56K modem, most MP3s can download in just a few minutes. MP3s are widely recognized as the most popular format for storing and listening to music on the World Wide Web. Listening to MP3s is easy. You just need to download a player, a software application that lets you hear music on your computer. MP3 is short for MPEG Audio Layer 3. MPEG refers to the Moving Pictures Experts Group, an organization that sets international standards for digital formats for audio and video. The file-shrinking technology itself was developed by the Fraunhofer Institute in Germany.
192 kHz/24-Bit Audio DACs
Performing at a full 192 kHz/24-bit level of resolution, these state-of-the-art digital-to-analog converters deliver audio performance that is second to none. They boast a higher dynamic range than standard D/A converters, and are virtually resistant to clock jitter -- which means you?ll enjoy the best performance possible from DVD-Audio discs and Super Audio CDs and cleaner sound from your regular DVDs and CDs.
Vector Linear Shaping Circuitry (VLSC)
Conventional D/A conversion methods reduce digital pulse noise at the conversion stage but can?t remove it completely. Previously only found on Onkyo?s high-end components, VLSC (Vector Linear Shaping Circuitry)employs a unique D/A conversion circuit to overcome this problem. Data is converted between sampling points and these points are joined with analogue vectors in real-time to produce a smooth output wave form. The result - a virtually noiseless, smooth analogue signal based on the digital source.
CD Audio
Based upon Red Book specifications, CD-Digital Audio is able to hold audio data at a sampling rate of 44.1 KHz and a sample size of 16 bits, to produce high quality stereo sound.
Doing More with Your iPod - Through Onkyo's Imaginative Sight and Sound
Simply place your iPod in the DS-A1 Remote Interactive Dock connected to any Onkyo RI-compatible amplifier/receiver to experience the powerfully rich sound of Onkyo audio-video components. Control your music from your RI remote and charge your iPod while you enjoy your iPod?s digital music -and photos - through the power of Onkyo?s expansive sound, from mini systems to separate components to home theater systems. Unlike purely iPod-dedicated systems, you can fully integrate the convenience and storage capacity of your iPod with all your other Onkyo home entertainment components - and share the experience with everyone.
CAMBRIDGE AUDIO TOPAZ CD-5 (BLACK) 6750 บาท
There?s no escaping the convenience of MP3 players and when connected to your amp they?re a great way of sharing your music at home. But if you?re really after a higher grade quality sound, you need a dedicated CD player. Offering incredible value, the CD5 opens up a whole new world of real hi-fi sound thanks to its true audiophile pedigree and careful selection of premium components including a Wolfson Digital to Analogue Converter.
Topaz CD5 CD Player features
Wolfson 8725 Digital to Analogue Converter
CD, MP3 and WMA playback from suitably encoded discs
Full remote control
Specifications
DAC    Wolfson Microelectronics
WM8725
Filter    2-pole Butterworth filter
Supported disc formats:    CD-DA/CD-R/CD-RW/CD-ROM
MP3/MP3 Pro/WMA
Max. Power Consumption:    15W
Dimensions (H x W x D):    80 x 430 x 305mm
Weight    4.3kg (9.5lbs)
[u]CAMBRIDGE AUDIO TOPAZ CD-10 (BLACK)  8500 บาท
[/u]
With a highly regarded premium Wolfson Digital to Analogue Converter (DAC), a superior servo system and precision transport, the CD10 will harness every drop of information from your favourite discs and deliver uncompromised signals to your matching Topaz amplifier.
The CD10 is simply poles apart from its rivals thanks to genuine hi-fi circuitry to truly enhance your music experience. Key to these is double-sided surface-mount technology which has enabled Cambridge Audio?s engineers to employ much shorter signal paths for improved precision and clarity.
Topaz CD10 CD Player features
Wolfson 8761 DAC (Digital to Analogue Converter)
Analogue and S/PDIF digital outputs
Full remote control
Specifications
DAC    (DAC) Convertisseur NA Wolfson Microelectronics WM8761
MP3/MP3 Pro/WMA
Dimensions (H x W x D):    430 ? 80 ? 310 ??
ตัวไหนคุ้มค่าที่สุดครับ ผมดูสเปคไม่ค่อยเป็นครับ สอบถามเพื่อเป็นข้อมูลก่อนตัดสินใจครับ เพราะอาจจะหางบได้ แค่ อย่างเดียวครับ
ถ้าแอมป์เกนโคนมีปัญหาพัง ก็คงต้องเอาแอมป์ก่อน แต่ถ้าเกนโคนไม่มีปัญหาอะไรใช้งานได้ดี ผมก็จะหา CD player มาทดลองใช้เพื่อให้สมบูรณ์แบบนักฟังเพลงเริ่มต้นครับ
หรือมีตัวไหนอีกครับ
แนวเสียงนุ่มนวล ครับ
ขอบคุณมากครับ
« แก้ไขครั้งสุดท้าย: 16 มกราคม 2012, 03:26:39 PM โดย cleaning »
Re: CD player
« ตอบกลับ #1 เมื่อ: 16 มกราคม 2012, 03:34:15 PM »
ถ้าเกนโคลนไม่พัง ก็ยกไปของลองร่วมกันที่ร้านเลยสิครับ น้าจะได้คำตอบที่ตรงใจน้าที่สุดครับ เพราะคำตอบมาจากหูของน้าเองเลย [smi_ley]
แล้วถ้าร้านเห็นแอมป์เราแล้วไม่ยอมให้ลอง ก็อย่าไปซื้อร้านเค้าครับ มีหลายร้านที่เค้ายินดีให้บริการครับ  fart-raccoon
Re: CD player
« ตอบกลับ #2 เมื่อ: 16 มกราคม 2012, 03:46:24 PM »
ไม่อยากไปพังลำโพงเขาครับ  laughhahaha ไม่อยากเสี่ยงครับ
ตอนนี้เกนโคนผมสมบูรณ์ที่สุดตั้งแต่ทำมาครับ ไร้เสียงจี่ฮัมใดๆเลยครับ ก็ไม่รู้ว่ามันจะสมบูรณ์ได้กี่วันครับ ผมเองก็จะไม่ไปยุ่งอะไรกับมันอีกแล้ว แต่จะว่าสมบูรณ์ทั้งหมดก็ไม่ได้ครับ มันจะมีอยู่ข้าง ที่ไม่ค่อยจะสมบูรณ์เหมือนจะซ๊อตๆ แต่พอเพลงร้องได้แล้วมันก็ปกติครับ
อยากทราบว่าคุณสมบัติของตัวใดด้านบน ดีที่สุดครับถ้าวัดตามคุณสมบัติทั่วๆไปครับ
Re: CD player
« ตอบกลับ #3 เมื่อ: 16 มกราคม 2012, 03:51:40 PM »
เอาจริงๆนะครับ ผมแนะเลย ยกไปทั้งลำโพง เกนโคลน แล้วเอาสายทางร้าน โทรไปนัดก่อนว่าจะขอเทสแบบนี้ ไม่งั้นฟังไม่ออกหรอกครับ ว่าเสียงแต่ล่ะตัวประมาณไหน มันยากนะครับ กับซิสเต็มที่เราไม่เคยฟังเลย แล้วมันก็จะวนมาปัญหาเดิมอีกได้ ถ้าเสียงไม่ถูกใจ
อย่างเวลาผมไปฟังตามบ้านน้าๆ ผมก็บอกไม่ได้ว่าเสียงของ cd ตัวนั้นเป็นยังไงถ้าไม่มีตัวเทียบ บอกได้แต่เสียงรวมๆของซิสเต็มนั้นๆ
ไม่อยากให้เสียเงินซ้ำซ้อนน่ะครับ ไหนๆแล้ว ยอมเสียเวลาซักหน่อย แต่ถูกใจเราแน่ๆดีกว่าครับ  [gr_in]
Re: CD player
« ตอบกลับ #4 เมื่อ: 16 มกราคม 2012, 03:54:53 PM »
คงยากครับ ผมไม่มีรถยนต์ครับลำโพงก็ตั้งพื้นอีกครับ cd ราคาต่ำกว่าหมื่นคงจะหาดีๆคงจะยาก ผมก็คงให้เพื่อนๆช่วยดูว่าตัวไหน คุณสมบัติดี ในภาค dac หรือฯลฯในเครื่องครับ หรือบางท่านอาจจะเคยใช้มาก่อน
เรื่องยกไปลองคงลำบากครับ คงทำไม่ได้ครับ
ผมจะเอามาใช้ร่วมกับพวกปรีหลอด ปรีopamp ด้วยนะครับ คงไม่มีปัญหาอะไรนะครับ
และก็หวังว่าภาค dac มันจะเหนือกว่าที่ผมใช้อยู่่ด้วยนะครับ ของผมมันเป็น pcm1973+637sm ครับ
« แก้ไขครั้งสุดท้าย: 16 มกราคม 2012, 04:12:35 PM โดย cleaning »
Re: CD player
« ตอบกลับ #5 เมื่อ: 16 มกราคม 2012, 04:04:48 PM »
 [unde_cided] งั้นคงต้องรอน้าๆ ที่ได้ฟังเสียงซีดีเหล่านี้แล้วล่ะครับ เพราะในลิสต์ที่เลือกมาผมเคยฟังแค่ 2 ตัวเอง ผ่านๆซะด้วยสิ [tremor-raccoon]
Re: CD player
« ตอบกลับ #6 เมื่อ: 16 มกราคม 2012, 04:34:57 PM »
แต่ถ้าเป็นผม  ยอมเก็บตังค์อีกหน่อยแล้วกด  C545BEE
Re: CD player
« ตอบกลับ #7 เมื่อ: 16 มกราคม 2012, 04:36:19 PM »
อย่าไปดูสเปคครับ เอาตามแนวเราชอบครับ เข้าไปฟังหลายยี่ห้อตัวไหนถูกหูถูกใจค่อยมาคัดเอาว่าจะเข้ากับลำโพงและแอมป์เรามั๊ย ถ้าชอบนุ่มนวลเสียงออกไปทางแฟ๊ลต ก็ลองฟัง NAD ดู Maranzt ออกทางกระฉับกระเฉง Rotel แนวออกใสเรียบร้อย มี magnet อีกตัวที่น่าไปลอง สุดท้ายก็ต้องไปฟังเองครับ
Re: CD player
« ตอบกลับ #8 เมื่อ: 16 มกราคม 2012, 04:37:29 PM »
+1 ครับ แบรนดัง รุ่นยอดนิยมใช่ว่าจะถูกหู เราครับ  clapping-1-2 clapping-1-2
Re: CD player
« ตอบกลับ #9 เมื่อ: 16 มกราคม 2012, 05:14:25 PM »
ตอนซื้อ CD ผมก็โพสต์ถามข้อมูลที่นี่
สุดท้ายผมก็ไปสอยเอา Marantz SACD รุ่น SA 7003 ครับ
ที่เลือกเอาตัวนี้ เพราะชอบน้ำเสียงที่ฟังแล้วมาในโทนอบอุ่น และเล่นแผ่น SACD ได้ด้วยครับ
ออฟไลน์ Guy_Audio
  • กระทู้: 2746
  • ถูกใจกด Like+ 93
Re: CD player
« ตอบกลับ #10 เมื่อ: 16 มกราคม 2012, 05:39:04 PM »
CAMBRIDGE AUDIO TOPAZ CD-5 ตัดทิ้งไปได้เลย เสียงค่อนข้างบาง [no-raccoon]
Onkyo DX 7355 ราคาตกมากคนไม่ค่อยเล่น
ลองเทียบดูระหว่าง NAD C515BEE กับ MARANTZ : CD-5003
แต่ผมเชียร์ MARANTZ : CD-5003 ครับ ครบเครื่อง แรงปะทะดี ฮาโมนิกยังดีอีก และน่าจะไปกับแอมป์ เกนโคลน ได้ดี
ส่วน NAD C515BEE ก็แฟลท ตลอดย่านอย่างคุณ ต่อภูเขียว ได้กล่าวเอาไว้แต่บางท่านก็ติว่าค่อนข้างจะจืดไปซักหน่อย
แต่ถ้าเล่นกับ เกนโคลน ที่มีอุปกรณ์ภายในน้อยชิ้นแนว บริสุทธิ์นิยม ที่ให้เสียงเปิดและรายละเอียดสูง
น่าจะไปกันได้ดีกับแนวเสียงจาก NAD  clapping-1-2
เอ่อ! เลือกยากครับ ระหว่างสองตัวนี้ ในราคาที่คุ้มค่าทั้งคู่
ถ้าเลือกไม่ถูก และชอบเสียงของทั้งคู่ ก็ต้องเลือกสวยถูกใจไว้ก่อนครับ
แต่ก็ยังมาสวยทั้งคู่อีก  [confused-raccoon]
Re: CD player
« ตอบกลับ #11 เมื่อ: 16 มกราคม 2012, 06:03:04 PM »
ขอบคุณมากครับ ตัวเลือกก็คงเหลือ สองตัวด้านบนครับ
แต่ว่า nad น่าจะนำเพราะถูกกว่าครับ [smi_ley] แต่ก็ไม่แน่ครับไม่ได้ทิ้งmarantz ครับ เพราะไหนจะเอาและใช้ยาวๆเพิ่มอีกนิดก็ยังพอไหวครับ
แอมป์ผมก็ไม่ได้ผูกขาดกับเกนโคนครับ วันหน้าอาจจะหาแอมป์หลอดมาฟังบ้างครับ เพราะต้องการหวานนุ่มซึ่งเกนโคนคงให้ไม่ได้ แต่ที่ใช้อยู่เพราะว่ามันทำง่ายที่สุดแล้วครับ ซึ่งตอนนี้ผมก็ใช้เกนโคนกับปรีหลอดครับ ส่วนปรีopamp พอเข้ากับเกนโคนแล้วมันค่อนข้างจะเป็นแนวสนุกๆเร็วๆ แต่ปรีหลอดตัวที่ผมใช้ก็ไม่ได้หวานนุ่ม ออกแนวรายละเอียดชัดเจนพริ้ว ซึ่งจะนุ่มกว่าปรีopamp หน่อย
Re: CD player
« ตอบกลับ #12 เมื่อ: 16 มกราคม 2012, 06:04:50 PM »
ไม่ไหวครับ งบไม่ถึงแค่ นี้ก็แย่แล้วครับ เรื่องเก็บคงยากครับผมเก็บไม่อยู่ครับ และถ้ารอไปๆมาๆก็อดไปเลยครับ ชุดโดยรวมของผมยังเล็กๆครับ คงไปไม่ถึง 545 ครับ
Re: CD player
« ตอบกลับ #13 เมื่อ: 16 มกราคม 2012, 06:08:21 PM »
ชอบแกงจืดก็จัด แน๊ด  ชอบผัดเปรี้ยวหวาน ก็มาร้าน  [yes-raccoon]
Re: CD player
« ตอบกลับ #14 เมื่อ: 16 มกราคม 2012, 06:12:12 PM »
ไปน้าcleaning  พี่เล็กบอกให้ไปที่ร้าน   [roll]3-2-1-raccoon
Re: CD player
« ตอบกลับ #15 เมื่อ: 16 มกราคม 2012, 06:23:41 PM »
 [gr_in] หูไม่ดีอย่างผม ฟัง CD-Rom ต่อไป เอิ๊กๆ
Re: CD player
« ตอบกลับ #16 เมื่อ: 16 มกราคม 2012, 06:25:30 PM »
ทางนี้ยัง TEAC 5010 อยู่เลย  [c--c]
Re: CD player
« ตอบกลับ #17 เมื่อ: 16 มกราคม 2012, 06:26:33 PM »
Marantz ไปลองฟังที่ปิยะนัส เซียร์รังสิต หรือที่ร้าน MRZ ที่เซ็นทรัลแจ้งวัฒนะก็ได้
NAD ก็มุ่งหน้าไปที่โฮมโปรรังสิต
แต่ผมอยากชวนไปที่เซ็นทรัล แจ้งวัฒนะก่อนครับ
Re: CD player
« ตอบกลับ #18 เมื่อ: 16 มกราคม 2012, 06:27:12 PM »
พี่เล็กบอก MARANTZ  ครับ
ออฟไลน์ Guy_Audio
  • กระทู้: 2746
  • ถูกใจกด Like+ 93
Re: CD player
« ตอบกลับ #19 เมื่อ: 16 มกราคม 2012, 06:40:06 PM »
ถ้าอยากเก็บไว้ใช้เลย MARANTZ : CD-5003 แน่นอนกว่าครับ
ผมชอบโทนของ MARANTZ มากครับถ้าทำเป็น ซีดีออกมา ตั้งแตรุ่นเก่า อย่าง CD 16 และ CD 17 แล้ว
ยิ่งตัวของคุณ อา Alcohol  เกรนเสียงเนียน สะอาดมากครับเรื่องแรงปะทะไม่ต้องห่วง
แต่ Airy ก็ยังมาแบบเต็มๆอีก [yes-raccoon]
Re: CD player
« ตอบกลับ #20 เมื่อ: 16 มกราคม 2012, 06:48:04 PM »
ผมแซวเล่น  [roll]ไปจริงอาจจะได้ของดีกลับมานะครับ ถ้าไม่เน้น NAD ตามหา 63se ในตำนานก็เป็นทางเลือก แต่ที่หลายท่านบอกต้องตระเวนฟัง ผมยังอยากได้เลยตอนที่ได้ฟังครั้งแรกเงินเดือน 8พัน [entreat-raccoon]
Re: CD player
« ตอบกลับ #21 เมื่อ: 16 มกราคม 2012, 06:52:16 PM »
ในส่วนตัวผมเอง ใช้ มาร้านมาตลอด ตั้งแต่เครื่องแรก ปัจจุบันยังใช้ ตัวใหม่ 6003 ลงตัวดีครับ
Re: CD player
« ตอบกลับ #22 เมื่อ: 16 มกราคม 2012, 06:59:43 PM »
Magnet CD11  แล้วตัวนี้ครับ
ส่วนใหญ่จะใช้แต่ มาร้าน กันเยอะนะครับ สำหรับ cd
ออฟไลน์ Guy_Audio
  • กระทู้: 2746
  • ถูกใจกด Like+ 93
Re: CD player
« ตอบกลับ #23 เมื่อ: 16 มกราคม 2012, 07:03:57 PM »
ถ้าอยากอุดหนุนของไทยก็ดีน๊ะครับ ผมพูดได้แค่นี้ [unde_cided]
Magnet สมัยก่อนกับสมัยนี้ ผมชอบสมัยที่พึ่งเปิดตัวมากกว่า
ออฟไลน์ Greenbull
  • กระทู้: 131
Re: CD player
« ตอบกลับ #24 เมื่อ: 16 มกราคม 2012, 07:05:29 PM »
คณะกรรมการยุยงส่งเสริมให้เสียทรัพย์สิน หรือ คยส.
มีหน้าที่กำกับการดูแลเพิ่มสภาพคล่องวงการเครื่องเสียง พร้อมให้คำแนะนำการปรับเปลี่ยนเครื่องเสียงแก่สมาชิกที่มีอาการคันหู อีกทั้งยังมีบริการให้ความช่วยเหลือ เป็นที่ปรึกษา เพื่อให้ได้มาซึ่งเครื่องเสียงที่มีประสิทธิภาพดี คุ้มค่า ราคายุติธรรม ราคาขายต่อเป็นเลิศ โดยมีคณะกรรมการผู้ทรงคุณวุฒิจากทุกภาคฝ่ายรวมศีรษะ ยุแยงตะแคงรั่ว เพื่อให้สมาชิกได้เป็นเจ้าของเครื่องเสียงที่ดีที่สุดเท่าที่สมาชิกจะสามารถกู้หนี้ยืมสินได้ ตั้งแต่การให้ทั้งคำแนะนำด้านไฟแนนซ์ให้เกินกำลังฐานะของสมาชิก จัดซื้อ จัดหา เจรจากับผู้ประกอบการ จวบจนวิธีเลี่ยงการตรวจสอบขณะย้ายเข้าเคหะสถาน และนิติกรรมอำพรางคู่สมรส
ล้อเล่นนะครับ [res]
Re: CD player
« ตอบกลับ #25 เมื่อ: 16 มกราคม 2012, 07:07:02 PM »
laughhahaha
cd player ถ้าผมชื้อ 10000 เข้าบ้านก็เหลือ 5 พันครับ
ล้อเล่นนะครับ [res]
Re: CD player
« ตอบกลับ #26 เมื่อ: 16 มกราคม 2012, 07:20:32 PM »
 [smi_ley] สำหรับผมตอนนี้ ต้องตามกฏข้าราชการไทยครับ ซื้อของ 1000 ต้องบอก 10000   บอกน้อยเดี่ยวหาว่ามีตังเหลือ  [thumbs-up-raccoon]
ออฟไลน์ yoyoeiei
Re: CD player
« ตอบกลับ #27 เมื่อ: 16 มกราคม 2012, 07:44:01 PM »
ซื้อมาปล่อยสัญาณ coaxial ไปให้ Dac หรือว่า เอาสัญญาณเสียง ตรงๆ เลยอ่ะครับ
Re: CD player
« ตอบกลับ #28 เมื่อ: 16 มกราคม 2012, 08:12:20 PM »
ผมจะเอามาปล่อย อนาล๊อคเข้าปรีก่อนครับ แล้วค่อยไปเข้าเกนโคนครับ DAC ผมรับ coax ไม่ได้ครับรับได้แต่ usb ครับ ถ้าผมใช้ผ่านปรีก่อน ผมก็จะไม่ได้แนวเสียงของ cd player ใช่ไหมครับ
Re: CD player
« ตอบกลับ #29 เมื่อ: 16 มกราคม 2012, 08:45:19 PM »
ตามมาเก็บข้อมูลครับงบผมตอนนี้แค่ C515BEE ก็เต็มที่แล้วแถมโดน 3 ตัววันนี้เล่นงานด้วยอิอิ
